MX 2610 prints only with Windows
  • dadub2
    • Sep 2020
    • 6
    Hello,
    I have a MX-2610 printer.
    This one is only printing with Windows but not wiht Mac OS (Mojave).
    I installed drivers from Sharp and installed the printer on the iMac.
    When I print, I hear the printer's awaikening, but nothing is printed, I have no sheet.
    With Windows, I'm able to print.
    Thank you in advance for your help.
    David
    Re: MX 2610 prints only with Windows
    Originally posted by dadub2
    Hello,
    David
    what version of the driver did you install?
    is it using the correct port?
    does the nic light light up when a print job is sent?
    are you using enet or firwire?
    so many questions so little info
    • dadub2
      • Sep 2020
      • 6
      what version of the driver did you install? : MX-C52c_1906a_MacPS.dmg Telechargements de pilotes - Trouver des pilotes - | Sharp Digital MFPs / Printers
      is it using the correct port? MAC chooses the right port
      does the nic light light up when a print job is sent? I don't think so
      are you using enet or firwire? Ethernet
      Thank you
      • spanky
        • Sep 2012
        • 468
        I believe you need to install a postscript kit on the copier to print from a Mac
        • romang
          • Aug 2011
          • 72
          • ntbann
            • Jan 2012
            • 626
            I found one for 49.99 on the inter web.
            • dadub2
              • Sep 2020
              • 6
              Hi everybody,
              THANK YOU for your help.
              1- OK, I do need to buy a PostScript MX-PK11, but first, how can I check if the print has one or not ?
              2- Do you think this is possible to find one in 2020 ? I live in Brussels, Belgium
              3- How install this kind of kit ?
              Thank you again for your help and have a GREAT W.E..
              • dadub2
                • Sep 2020
                • 6
                Hi everybody,
                Hi again,
                I would like to let you know that I found a YouTube video who helps me to resolve my problem with the kit.
                The only problem, I cannot print in colour... just in black.
                I use Generic PCL laser printer (generpcl.ppd).
                Any idea please ?
                Thank you again.
                  Hi again,
                  Any idea please ?
                  Thank you again.
                  no generic driver ... use model specific pcl 6 driver win10 has troubles with pcl5
                  • dadub2
                    • Sep 2020
                    • 6
                    Thank you for your reply
                    I'm under MAC OS 10.14 (Mojave) and not Windows 10.
                    Do you know which drive I have to use ?
                    Thank you again.
                      Thank you again.
                      you said you are printing to WIN10 & MAC which is it?
                      YOU HAVE BEEN TOLD OVER N OVER WITHOUT THE PRINT KIT YOU CANNOT PRINT IN POSTSCRIPT WHICH THE MACS -=REQUIRE=- POSTSCRIPT..
                      CLEARLY YOU SEEM TO BE OVER YOUR PAYGRADE ON THIS ISSUE....
                      only now do you tell us it's a MX2610M ( which doesn't show on the sharp website ) you also stated this in your original post
                      "I have a MX-2610 printer. (notice no N nor M mentioned)
                      I installed drivers from Sharp and installed the printer on the iMac."
                      seems like you don't know what you have or how to configure it..
                      HIRE A TECH
                      • spanky
                        • Sep 2012
                        • 468
                        Sharp has a print driver for the MX-2610N that supports Mac OS 10.15 version 2.1.1.1
                        Would that work for you?
                        • xring1958
                          • Mar 2016
                          • 166
                          Yes using a generic driver you can print in black you can go into sim 22-10 t see if yours might have it. When you are installing the PS driver make sure you choose the IP address don't let the mac find it . Here is my cheat sheet
                          1. Go to Sharp USA Downloads page
                          2. Select correct MFP and download OS PACKAGE
