Sharp mxm623
+ More Options
Posts
  • davebtech
    • Apr 2015
    • 170
    Sharp mxm623
    Replaced tandem paper trays drive clutch unit.Turned them both off to users a while ago but cant find setting to turn them both on again? Any help thanks Dave.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp mxm623
    If you're talking about the check boxes, they are in system setting - paper tray setting and click on each tray then click on change. The boxes for print copy and fax should be there
    Good luck
    Bil
    • davebtech
      • Apr 2015
      • 170
      Re: Sharp mxm623
      Good luck
      Bil
      did that and machine says tray 1 ready to open , very strange,never seen that one.
      • davebtech
        • Apr 2015
        • 170
        Re: Sharp mxm623
        Good luck
        Bil
        went back to check connections,the 2 pin connector to lift motor fell off during drive unit install.little bit of a cluster..... in there.Thanks for help bil
