MX2630 switching itself off
  • Leebs14
    • Feb 2014
    • 457
    [Dead] MX2630 switching itself off
  • copiertec
    • Jan 2016
    • 2205
    Re: MX2630 switching itself off
    Are they mistaking power save for the machine shutting down? I get that a lot clients complain the machine is off when it is simply in power save mode.
    • Jamiesdad2
      • May 2009
      • 29
      I have seen this happen with compatible toner. Pull the toners out of the machine and see if the machine stays on. If so install the toners one by one until you find the defective toner.
      • Dcopyman
        • Apr 2020
        • 34
        Sometimes a corrupt print job can cause machine to keep cycling on and off, try disconnecting network cable and see if that corrects issue
