MX-3110N Faded Prints, Copies Good
  • mioduz
    • Oct 2020
    • 34
    I am a small business owner and recently acquired a used Sharp MX-3110N Copier. To test at the time of sale I made some Color photocopies which turned out great. Once Connected to my network sending color image prints to the machine yield a faded result. I can not locate a local service company that will work on this printer. Any advice is appreciated.
    Black Text Prints good
    Color copies are good
    Color prints are faded
    • 16406
    Re: MX-3110N Faded Prints, Copies Good
    Try printing out internal test charts.
    If the print quality is fine, then this could be a software issue. I would recommend you go ahead and do a clean install of the printer software.
      what are the lifes on drums... dev units .. belt?
      sounds like a print driver issue..
      what driver are you using ?
      copys are good b n w prints are good so we know the supplies are working properly..
      points to your print driver
      with out more info that's the best for now.
      • mioduz
        • Oct 2020
        • 34
        Here are outputs from just a copy on the glass, as well as scanned in and printed from windows image viewer as well as printed by dropping the file directly into printer ftp directory
        The scanned image looks good on pc
          https://i.imgur.com/sqshnU7.jpg
          still waiting on WHAT DRIVER you are using?
          • Blizzoo
            • Aug 2013
            • 608
            Hmm I'm thinking maybe in the print driver you have something like Toner Save set to ON? Just a guess...
              I asked about that many messages ago... crickets
              • mioduz
                • Oct 2020
                • 34
                Printing using a multitude of drivers. All results are nearly identical
                Drivers Acquired from Sharp Website
                WSD
                PCL6
                PPD
                PS
                Corrrect me if I am wrong but wouldnt printing from the Sharps internal FTP (drag and drop file directly to sharp) eliminate the trouble shooting from the software side as well?
                That is partially why i did not address the print driver
                • mioduz
                  • Oct 2020
                  • 34
                  Checked internal settings
                  "Toner Save Mode"
                  is turned off for all 3
                  Copy
                  Printer
                  Prints (Document Filing)
                  • danny464
                    • May 2019
                    • 81
                    What if you load the file to a usb and print from there?
                    • mioduz
                      • Oct 2020
                      • 34
                      Faded as seen previosly
                      • danny464
                        • May 2019
                        • 81
                        can you upload the file you are printing?
                        • miller01123@gmail.com
                          • Jun 2019
                          • 55
                          You could try doing Auto Color Calibration under Settings- System Settings/Printer Settings/Color Adjust or you could try Restore Factory Defaults under System Settings/Storing/Calling of System Settings
                            Originally posted by miller01123@gmail.com
                            You could try doing Auto Color Calibration under Settings- System Settings/Copy Function Settings/Color Adjust or you could try Restore Factory Defaults under System Settings/Storing/Calling of System Settings
                            he is having PRINTING problems.
                              • Jun 2019
                              • 55
                              Thank's PHIL! Should have said Printer Settings instead of Copy Function Settings. Edited my previous post.
