MX-3110N Faded Prints, Copies Good
  • copiertec
    • Jan 2016
    • 2192
    #46
    Re: MX-3110N Faded Prints, Copies Good
    do us all a favor...
    1) make a small contribution to keep CTN running
    2) post a manual request here----> https://www.copytechnet.com/forums/s...nual-requests/
    the contributor badge will show the guys with the manuals that:
    1) you made a contribution
    2) you are likely to get quicker service on your request
    you seem to be stumbling with simple things .. the manual is your best recourse .. Copiertec and I have tried n tried
    hell 5 PAGES to this thread and the thread is only 1 day old.
    another suggestion is to HIRE a TRAINED tech..
    you've gotten alot of help for NADA - ZIP - ZILCH so far.
    some people shouldn't try to fix their own machines.
    Very eloquently written, sir. I am now unsubscribed from this thread.
    • OlliK1969
      • Nov 2016
      • 310
      #47
      Hi
      sometimes the problem is in front of the device
      • mioduz
        • Oct 2020
        • 34
        #48
        Originally posted by chubblies
        Try 46-74 for both copy and print. Also check 26-18 for TS mode is off. If not this might be the SD card. Had the same on a MX2310 where you would calibrate it, it would try to save the calibration to the SD but it would fail, so it would revert back to factory settings, but only on print...
        I can confirm that toner save is turned off for all modes
        46-74 I ran and found the output a bit confusing
        Seams like the corrected patch is faded. Maybe I'm off here but the original patch seams accurate
        • chubblies
          • Jun 2011
          • 154
          #49
          • mansart
            • 852
            #50
            Try the following.....
            Do test print SIM 64-5, then do a test print with SIM 64-2.
            Are they both light? Or is one better than the other?
            These test prints originate from different boards and can point you in the right direction.
            • mioduz
              • Oct 2020
              • 34
              #51
              I tried replacing the sd card (powered off) the system will now not boot up. Fans are all running but the screen does not show any life
              This is both the case with the new sd card and original
              • chubblies
                • Jun 2011
                • 154
                #52
                Did you image it before replacing it?
                It has files loaded so although it will show blank it does contain system files that are model specific
                • mansart
                  • 852
                  #53
                  Also check...
                  Systems Settings...(login as admin)....Printer Settings....Default settings....Print Density Level
                  default is 3
                  If you did factory reset these should be back at 3 already, but worth a peak
                  • mioduz
                    • Oct 2020
                    • 34
                    #54
                    I got the system rebooted up. I think i may have accidentally flipped to "boot from SD" switch to OFF, when wrestling with the card. Everything is functioning as it was before (faded prints) with the original SD card. I will attempt to image the old card onto a new card in a bit.
                    • mioduz
                      • Oct 2020
                      • 34
                      #55
                      64-5 came out in color faded
                      64-2 came out in Grey Scale faded
                      • mioduz
                        • Oct 2020
                        • 34
                        #56
                        I Imaged the SD card (MFP now running on new SD Card with original Data)
                        Output is the Same
                        I ran 46-74 SIM.
                        Output is same as before
                        • mioduz
                          • Oct 2020
                          • 34
                          #57
                          Also check...
                          default is 3
                          they are set to 3
                          • mansart
                            • 852
                            #58
                            Print and post a 22-6.
                            Also send a print job.....quantity 5.
                            when first print begins to exit open the front door.
                            pull out primary transfer.......iis the image faded on the belt prior to secondary transfer?
                            • mioduz
                              • Oct 2020
                              • 34
                              #59
                              Yes the image is faded
                              Ill post 22-6 a bit later when i have a moment
                              • mioduz
                                • Oct 2020
                                • 34
                                #60
                                MX-3110N_20201021_162635.pdf - Google Drive
                                here is a link to the 22-6
