How to program Capri MFP PRG u500c1
  • sht
    • Oct 2020
    • 7
    [CQ] How to program Capri MFP PRG u500c1
    hi to all , i am newbie in here and before i didn't program any of sharp copy printer device , anyone can help me ?
    i have a sd card with name Capri MFP_PRG u500c1 that when i put it on my device not working but when i insert another sd card with this name device boot without any problem . i want to know how can i program that sd card or copy correct SD card to wrong SD Card ? i check some of post and see HDD raw disk but both of sd card are unallocated in my windows ! i must use specified device or operating system to get backup from my sdcard ?
    please help me . i have many sharp device with this problem and i can not fix that , my sdcard is 8 gb
  • ntbann
    • Jan 2012
    • 626
    Re: How to program Capri MFP PRG u500c1
    Take your good sd card and plug it into your computer. X out of whatever windows tells you to do. Open raw copy and copy the card. Now put your blank card into your computer and copy the file you saved to that card. Done.
    • sht
      • Oct 2020
      • 7
      thanks for your answer
      i am doing what that you said , i hope this work , are you sure this is ok ? i ask this because my sharp devices is not here , i must test sd card tomorrow .
      and another question is can i buy new sdcard with other brand like samsung or kingston brand or i must buy specified sdcard ?
      thank you
      • ntbann
        • Jan 2012
        • 626
        We use sandisk cards. Just have to make sure the card is the same size or larger.
        • sht
          • Oct 2020
          • 7
          thank you so much for your help
          • sht
            • Oct 2020
            • 7
            hi again and sorry for ask many question
            but when we want to save image file there are two option : 1- Image Compress"imgc file" 2- raw image "dd file"
            i save image as imgc file , that is true or i must save as dd file ?
            and also when i clone my backup to new sdcard and get a backup from new sdcard that was a little bit less than first backup file
            my first backup file was 279,884KB but second backup from new sdcard is 279,876 KB
            is that make problem for me ?
            • sht
              • Oct 2020
              • 7
              and last question is that if i send you Model name of my sharp device then can you send correct backup file to me ?
              • sht
                • Oct 2020
                • 7
                Hi
                is there any place for download backup of other copy hdd ?
                • emeland85
                  • Jun 2021
                  • 3
                  Hi sht,
                  i have a SHARP MX-M314n its sd card damaged.
                  Plz. Can you transfer ou upload me the backup of your SD card.
                  I already have a backup of SHARP MX-M315NV (Nova-EV MFP_PRG u302v1) someone needs it.
                  My email : emeland85@gmail.com
                  Best Regards.
                  • emeland85
                    • Jun 2021
                    • 3
                    Hi Sht
                    Plz, Can you transfer ou upload me the backup of your SD card.
                    my mail: emeland85@gmail.com
                    Best Regards.
                    • Lukzy
                      • Oct 2021
                      • 2
                      Originally posted by emeland85
                      Hi Sht
                      Best Regards.
                      Hi, i need those files, i looked everywhere but i did not find any solution. Please help
