MX-4070 fax issue
  • copiertec
    • Jan 2016
    • 2205
    #16
    Re: MX-4070 fax issue
    Thank you, I was just looking at the fax service manual...that damn thing is a rabbit hole with all the different settings.
    • mojorolla
      The Wolf
      • 2608
      #17
      Thank you, mojorolla, yes, I did make sure the cord is only a two line cord, but I did not check the cord going into their "fax finder" box/switch, I thought about that and am going back to check it.
      Do you know which soft switch it is to turn down baud rate to 9600? (I will search for it in the fax service manual)
      There is that Multitech Fax Finder box that they are using that takes the faxes and switches/converts the fax to email (I have a small suspicion this could be causing an issue) but, it did not cause an issue on the MX-3100N that was in its place.
      I do have the fax set to print out on error only. You are correct on the forwarding email address needing its own address in the address book, why I do not know as it goes to another address.
      The Multitech Fax Finder is doing the fax to email conversion ? Have you tried using the built in Sharp Fax Forwarding feature to email ?
      • copiertec
        • Jan 2016
        • 2205
        #18
        That may be my next discussion with the client, if the fax ss adjustments do not work. I almost already know what the client is going to ask, "why did it work with the old machine and not the new one?"
        I changed softswith 28 bit 7,8 to 1 abd softswitch 29 bit 7,8 to 1
        I also turned off ecm and checked the digital line network icon on the web interface. I will see how this works when I follow up on Monday, let me know if you can think of anything else, mojorolla.
        I also went to the Multitech fax finder and plugged a 2 line phone cord into it as well. Fingers crossed. Thanks for the help.
        • copiertec
          • Jan 2016
          • 2205
          #19
          I stayed at the clients office for a few after posting. All the faxes are going though okay now. But, here is the issue when it is receiving a fax... when you go into folders address book on the touch screen, to scan, you can not highlight that folder and scan to it until it is done processing the fax. When it is receiving a fax, if you go into easy scan, telephone mode pops up and it stays in the fax address book, instead of the folders address book, but if I go into the the folders icon on the touch panel, I can see all the addresses, I just cant highlight them to scan to them, almost like the mfp can only handle one thing at a time as far as scanning goes. But the client can copy and print while it is receiving a fax and in that telephone mode.
          • Prints Charming
            • Aug 2019
            • 189
            #20
            If you're in Scan mode and the telephone mode overrides the display, it sounds like you have a line noise or a line low voltage issue, which causes the fax to think the extension port is off-hook.
            To disable all of this, change fax soft switch 114, bit 8 to 0.
            • copiertec
              • Jan 2016
              • 2205
              #21
              Thank you, PC, I was thinking the same thing this weekend, line noise or voltage. I was also thinking about unplugging that fax server and see what happens as well. Thanks for the tip, I will make the changes and see what happens.
              • copiertec
                • Jan 2016
                • 2205
                #22
                As of today, the client, still has not called Comcast to check the lines. However, changing bit 8 to 0 has fixed the issue. I told the client to call Comcast because there is an issue with the line causing the issue..I am willing to bet, it never gets called in. How did you come across the 114 bit 8 to 0, PC?
                • Prints Charming
                  • Aug 2019
                  • 189
                  #23
                  However, changing bit 8 to 0 has fixed the issue. How did you come across the 114 bit 8 to 0, PC?
                  Nice.
                  This switch has been known for many years, as far back as the first MX models with the MXFXX1. Note: its a different switch number in some older fax kits. Search for 'external telephone' in the fax service manual and you'll find the appropriate switch for that particular model fax.
                  It's saved the day for me many times when noise or low voltage on the line causes the fax to activate immediately when entering any Image Send mode. Disabling External Telephone stops this noise and low voltage detection.
                  This isn't going to get called in now because 'its fixed'.
                  • copiertec
                    • Jan 2016
                    • 2205
                    #24
                    [QUOTE=Prints Charming;1665909]Nice.
                    I've been working on Sharp's since 94, I was unaware of this ( I obviously did not get the memo), I've marked it down in my notes, thank you.
                    • Demon33
                      • Jan 2019
                      • 38
                      #25
