sharp ar-m450n
  • DINGO
    • 661
    sharp ar-m450n
    hy
    what is yours opinion about H2-02 in ar-m450,??
    thanks
  • ZOOTECH
    Senior member of CRS
    • 3375
    H2 is a thermistor problem, but I have not seen a sub -02 code for this model.
    • RSCA
      • Jul 2008
      • 112
      The manual lists H2-00 and H2-01 both thermistors HL1 and HL2 open, there is no 02 sub-code. Did you power the machine with the fuser out? If so this needs to be reset with sim 14.
      • DINGO
        • 661
        • CopierTechofOmens
          Agitating Artificer
          • 268
          Check to see that the toner sensor is working sim (25-1). I have had this problem turn out to be toner motor/ Main PWB related.
          sigpic
          • DINGO
            • 661
