Sharp MX 4141 Network Time out error
  • Alex1
    • Oct 2012
    • 285
    I have a Sharp MX4141 i have put in all the right credentials to scan to email for DNS and the SMTP and I keep getting a time out error. So I decided to authenticate through Gmail I get the same error. I do a test through the web interface and I get a succeed response. I was wondering if there's anything in service mode for me to check or has been switched off. Any help would be appreciated.
  • copiertec
    • Jan 2016
    • 2211
    Re: Sharp MX 4141 Network Time out error
    What is the firmware version?
    • spanky
      • Sep 2012
      • 468
      Are they using G suite?
      There is a setting in the g suite to allow communications with an unknown device (I believe that is the verbiage for it)
      That has to be turned on in the g suite account.
      • Alex1
        • Oct 2012
        • 285
        Thanks for the response. But even through telstra where you don't need to authenticate i still get the same error. If I test other machines via telstra credentials they work fine.
        • Alex1
          • Oct 2012
          • 285
          Firmware Version04.00.RD
          • copiertec
            • Jan 2016
            • 2211
            latest version which allows TLS 1.2 is 400R2C0B
            • Alex1
              • Oct 2012
              • 285
              Thank you for that. Now I'll need to figure out where to get it from. I appreciate it.
              • copiertec
                • Jan 2016
                • 2211
                PM me
                • Blind Avocado
                  • Jan 2021
                  • 40
                  Did this get resolved? One other suggestion is under System Settings - Image Send Settings - Scan Settings, make sure you put the Reply email address. It must be the same address as in the SMTP settings or it will not authenticate.
                  • Alex1
                    • Oct 2012
                    • 285
                    Still hasn't been resolved as I need the Australian version firmware to complete. I have already tried what you have mentioned with no luck. I appreciate the help.
