L4-16 code on a MX4141N
  • Tonerkiller
    • Oct 2012
    • 668
    I have a machine with this code. I replaced the fuser and I still have the constant code. Any ideas?
  • nanohitmen
    • Apr 2019
    • 115
    Re: L4-16 code on a MX4141N
    • Description:Fusing pressure release trouble
    • Causes:Fusing pressure release sensor trouble. Fusing pressure release motor trouble. Pressure release drive gear and pressure release idle gear trouble. PCU PWB trouble. Connection trouble of the connector and the harness.
    • Remedy:Replace the fusing pressure release sensor. Replace the fusing pressure release motor. Replace the pressure release drive gear and the pressure release idle gear. Replace the PCU PWB. Check connection of the connector and the harness.
    • mojorolla
      The Wolf
      • 2608
      This model has sensors which are prone to failure. You can enter SIM mode and test the motor and the sensor.
      If the motor works, but he sensors fails, you generally get a clunking noise as the machine turns the release system shaft.
      • Tonerkiller
        • Oct 2012
        • 668
        Thank you, I will try that. we are bringing it to the shop.
        • Tonerkiller
          • Oct 2012
          • 668
          It was the sensor on the pressure release motor assy. Thank you.
          • RascalMJ
            • Mar 2009
            • 174
            ...but replacing the fuser didn't solve the issue? Is this assembly separate from the fuser?
            • ntbann
              • Jan 2012
              • 628
              Yes they are separate.
              • RascalMJ
                • Mar 2009
                • 174
                That makes sense then. Thanks
                • Nachoman4life
                  • Oct 2007
                  • 212
                  I have had a handful of these that were due to a failing separation motor, something to keep in mind if it comes back.
                  Where the heck is my spring hook?
