Mx2640
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    [CQ] Mx2640
    Hi guys. This one is for any one who does Sharp. Can you shed any ideas with this issue.
    Sharp Mx 2640. Customer called saying poor cq. The leading edge looks ok (about an inch in) looks like magenta and yellow are ok. Also when I got there I had e7 93 which is image process trouble. The mc would not print a test page either so I reformatted hdd and that sorted the e7 93 and test page not printing issue. I did a panic stop and the image was not great on the primary so rules out fuser and secondary transfer. Any ideas? Will get image uploaded
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • ntbann
    • Jan 2012
    • 628
    Re: Mx2640
    Developer and drums. What are your maintenance counts? Not much info here!
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Re: Mx2640
      It has been refurbished 2 months ago with new devs and drums. All consumables are way under life.
      • ntbann
        • Jan 2012
        • 628
        Re: Mx2640
        Example
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          Re: Mx2640
          Here are some samples, as you can see it looks like black and cyan are poor, although its good for the first part of the page, this issue suddenly occurred, it looks like bad c and k developer but this issue on both colours happened at the same time.
          • mansart
            • 852
            Re: Mx2640
            Are these prints or copies?
            Do an internal print using 64-01 A=9
            and one using 64-5 A=1
            what does the color on these look like?
            If these are copies, try taking the machine out of manual exposure.....any difference?
            • ntbann
              • Jan 2012
              • 628
              Re: Mx2640
              Have you run a calibration step by step yet?
              • Servicetech
                • Apr 2006
                • 7
                Re: Mx2640
                Check the secondary transfer belt unit. I have had a piece break and the transfer roller under the belt was out of place. It causes all kinds of weird quality issues.
                • copiertec
                  • Jan 2016
                  • 2211
                  Re: Mx2640
                  Were the drums OEM? Seems you have issue with the black the most. OEM toners? Were all the proper calibrations followed? Did you check your primary belt to make sure black roller is working properly? also as mentioned as well, how is the secondary trans belt looking? I have gone as far as pulling out the laser unit to make sure all the glass is clean as well in instances like this, just to make sure no developer, toner or dust is blocking the glass just to eliminate it being a cause, it just takes an extra 15 min.
                  • leo34staffs
                    copierman
                    • Aug 2007
                    • 503
                    Re: Mx2640 Solved
                    Hi Guys, I have sorted this, it was the ptc, it was attached at either end but nothing in the middle, not sure if the customer has messed, although I had no charge related code, I did get e7 93 which may have been caused by the arc. I will upload some samples printed from 64-01
