arm-620 clipping trailing edge of copies
  • gregu33701
    • Oct 2008
    • 31
    have a 620 clipping (blanking) the trailing edge of copies at variable lengths , problem is very intermittant , never observed by tech , 100's of copies can be made , no print available , off glass , feeder any paper source , tech in feild pulling his hair out, trying to help him , found article on sharpnet about possibly reg sensor (ppd) or the sensors in the tray 2 mini transport tray above tray 1 , anyone seen this weird issue?
    clipping is clean line , no fading to blank
  • OMD-227
    yes, you are spot on about the problem.
    If your machine was produced before August 2004, replace interface PG guide.... part # PGIDM2038FCZ1 for better performance of MPRD2 sensor.
    Seen it before... probably will again. This part fixed my problems last time.
      • 23009
      I don't know if this will be any help, but this is the only reference I could find:
      Staples off the edge of the paper. Also incorrect trail edge blanking. Customer has set tray #1 to A4 size paper. Set tray #1 to letter size paper.
      • gregu33701
        • Oct 2008
        • 31
        arm 620 clipping
        thanks waza , will order part this morning , love the efficiency of this board
