A H5-01 is a more common code if it is a H5-01 her is what it means.
H5 01 Content 3 continuous POD1 not-reaching JAM detection
Detail 3 continuous POD1 not-reaching JAM detection
Cause Check that the fusing JAM is completelycancelled. (Jam paper may be remained.)
POD1 sensor trouble or improper harness connection
Improper installation of the fusing
harness.
Check and remedy
Check JAM paper in the fusing section. (Winding, etc.)
Check POD1 sensor harness. Check the fusing unit installation.
Cancel the trouble with SIM 14.
Another words you have had 3 continuous jams at the fuser unit usually caused by broken fuser pawl.
