MX-M365 adf issue
  • deputydogg
    • Nov 2015
    • 172
    MX-M365 adf issue
  • copiertec
    • Jan 2016
    • 2205
    Re: MX-M365 adf issue
    Have you tried cleaning the document feeder? Removed covers and cleaned sensors and inspected? That would be a good start.
    • deputydogg
      • Nov 2015
      • 172
      I have not yet, but I will Monday.
      • driving lots of miles
        • Jun 2016
        • 398
        Originally posted by deputydogg
        Randomly when you put a document in the document feeder it says open cover and remove jam. Opening and closing the ADF cover doesn’t always clear the code. It almost seems like there is an issue with the last sensor that the paper passes before it’s scanned.
        This is the first one of these I have ever seen so I’m not even sure how to get the actual jam code?
        Any suggestions ?
        Dave
        We have had this issue several times and the sensor flag in the lower transport unit in the ADF, it gets knocked out of place when the customer removes a Jam
        • copiertec
          • Jan 2016
          • 2205
          I would suggest a can of compressed air and a screwdriver, covers are not to difficult to remove. Blow it out good, clean and check sensors, clean all rollers and go from there, dirty sensors cause strange things. I had one that would not recognize a document or show a jam when it was loaded, it was a dusty environment, so every couple of months, I would blow it out clean it up good and they would be good for the next couple of months.
          • boutn
            • Jun 2016
            • 547
            Any suggestions ?
            Dave
            Jam Code?
            • austonrush
              Sharp & HP Tech
              • 234
              Please check your jam code in sim 22-6, also check your adf sensors in sim 2. Once done you'll know exactly which sensor is the issue. From there you can determine whether your sensor is dirty, has a jammed flag or is dead and requires replacement.
              • copiertec
                • Jan 2016
                • 2205
                We haven't heard back in over a week , so I am assuming the issue is fixed. Sharp came out with updated sensors for this series, however, cleaning and sometimes a extra wrap on the springs usually does the trick. I always enjoy getting to the sppd3 sensor on this series.
                • austonrush
                  Sharp & HP Tech
                  • 234
                  yeah we wrap that spring an extra time as well! Sensors were quite unreliable from sharp for a couple years on all their machines from that era... better now at least! Still got a lot of these machines in the field.
                  • deputydogg
                    • Nov 2015
                    • 172
                    I took ADF covers off , blew out all sensors, wrapped spring another round. No issues since.
                    Sorry for the delay.
                    Dave
