sharp mx 5001n fan
  • clark
    • Sep 2016
    • 109
    sharp mx 5001n fan
    I have searched the manual for the fuser cooling fan. Its making noise. Does any one have the part number so i can order it. Thanks
  • copiertec
    • Jan 2016
    • 2206
    Re: sharp mx 5001n fan
    What manual did you look at?
    In the parts manual its located in section 37, it's hard to miss them as they have the updated circles above them, look at #30. Are those the fans you are looking for?
    • clark
      • Sep 2016
      • 109
      Thanks. I do see it. I have ordered it thru sharp.
      • repn1999
        • May 2010
        • 310
        be sure to check the screws on the ducts to make sure they are tight. that will cause a similar sound to a bad fan and you will end up ordering a fan for nothing. also for what its worth I would just replace the delivery unit. both fans cost near the same as the entire unit and that way you also get the mods added to the delivery unit over time. just a word of advise from someone who has worked on this thing since it was new. lol. have a great day
        • Toner Boy
          • Aug 2007
          • 365
          Be sure it's not the fan above transfer belt and black drum unit...L4-45 codes
