Has anyone seen something like this ? ( I.Q. )
  • tmw
    • Dec 2013
    • 259
    Was here twice. Both times they said 'our scans look like a waterfall '. By the time I got there, the problem wouldn't repeat itself both times. They definitely had the scans on more than one computer. It seems like it did it a few consecutive times about an hour or two before I got there, but not when I arrived. I cleaned & reseated the connections between the ccd & scanner boards. I flashed up the latest firmware. All the copies I made, & all the scans I sent to myself and the different terminals all came out correct. They called a month & a half later with the same thing. When I got there it was the same situation. I tried a scan board from another machine to see what would happen, but apparently it wasn't compatible & froze up the machine. I considered changing the ccd board assy. but that looks like an involved operation that would take too long to pop it in & out just to test. The closest I could find to a scanner calibration was sim 48-1 to make sure everything was at default. On the following attachments, the arrow indicates the direction the originals were fed in the doc feeder. I tested both adf & flat glass. As I said, it never did that for me. They've had this machine for a few years without this problem. It should happen all of a sudden temporarily, go away for over a month, come back again briefly, then go away again before I get there ? It seems to me if it were a board, it would be a permanent defect until it was changed. If it was software, what is there besides firmware ? After observing it, I can't detect a mechanical fault. Strange days indeed.
  • mojorolla
    The Wolf
    • 2608
    Re: Has anyone seen something like this ? ( I.Q. )
    OK, if I may begin at the beginning ...what model are you working on ?
    Most Sharp scanner boards have an eeprom chip that needs to be swapped from the old board to the new.
    I think its SIM 63, you can test the ADF and platen CCDs. If the gain value is double digits, the CCD is failing.
    • tmw
      • Dec 2013
      • 259
      Sorry I forgot with other stuff going through my mind. Mx-2615. I could only edit the tags. I already swapped the eeprom. When I got there I noticed one said aries & the other gemini. I thought I'd try it for the heck of it. Ended up putting original back in. If it is a board, how would it malfunction only for a brief time, only twice ?
        • 23007
        I've got a Toshiba eS3005AC doing something similar intermittently. They call it "Blurry scans".
        On my machine, it was only affecting scanning through the DF, only 300/400/500dpi, only color scans, only photo and text/photo original types ... on & on like this. Any function that requires more memory or larger file size seems to trigger it. I have been treating the situation like a new CCD installation (without changing the CCD). On the Toshiba there is a data backup from System board to SYS LGC board (probably some sort of base color tables), and a white plate shading adjustment. Each time the scanning quality is restored.
        I don't know if any of this is helpful, but there it is. =^..^=
        • mojorolla
          The Wolf
          • 2608
          Eeproms on a scanner board are very small and have 8 tiny metal legs. If they say Aries & Gemini (2 families, will not work btw) those are most likely the memory chips and not the eeprom.
          • nanohitmen
            • Apr 2019
            • 115
            I had that issue on a different machine I had to clean the LSU. Not sure if it will fix what you have going here but it doesnt hurt to look.
