Sharp MX-M3060N copies coming out reduced and having black banner on top
  • Acd2005
    • Apr 2017
    • 7
    [Misc] Sharp MX-M3060N copies coming out reduced and having black banner on top
    Hello Team,
    I have just initialized a new Sharp MX-M3060N that has been sitting in the box for 3 years and it prints fine as can be seen from the attachment Original.pdf, however when making a copy it prints like the attachment Copy.pdf
    Can anyone shed a light as to what is going on in this unit? Another issue is it wont allow me to enter with the default "admin" password when attempting to enter the Administrator Console
    Please assist guys....
  • mojorolla
    The Wolf
    • 2627
    Re: Sharp MX-M3060N copies coming out reduced and having black banner on top
    Looks like the copy ratio is reduced and the "black band" is the machine trying to fill the void.
    Does it do this from ADF and platen glass ?
    Enter SIM mode and run 48-1, then 50-28
    • Prints Charming
      • Aug 2019
      • 189
      This is not a new device if the admin password is not working. Either perform Data Initialize or contact Sharp to perform admin password reset procedure.
      What firmware is installed on this device? There's been a lot of updates over the last 3 years.
      When you place the original on the glass, what size is detected in copy mode?
      When you place the original in the document feeder, what size is detected in copy mode?
      Looks like the original is not detecting as the correct size, causing reduction. The image is correct, but incorrectly reduced and offset.
      • Acd2005
        • Apr 2017
        • 7
        Yes it does it in both ADF and platen glass.
        • Acd2005
          • Apr 2017
          • 7
          Also tried with a3 paper does the same thing. also tried A4R did the same thing
            • 23009
            On other Sharps I've seen a laser unit failure cause symptoms like this, and there isn't enough adjustment to bring it back to where it needs to be. =^..^=
            • Acd2005
              • Apr 2017
              • 7
              Tried disconnecting the wiring from the document feeder as i wanted to dismantle the entire top, reached the part of dismantling the display but kinda got fedup so returned it back and tested it worked fine in both color and black......switched it off, changed the document to a new image to copy and back to its old tricks again....
              Also scanning to usb does the same thing
                • 23009
                That rules out the laser. =^..^=
