MX2314 - NETWORK SCANNING
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] MX2314 - NETWORK SCANNING
    So I have a customer who has a MX2314 set up to scan over SMB to a folder on their server, all worked fine until 29th April when it stopped working, looks like a microsoft update has stopepd this and i can onlt think its the SMB 1.0 or similar has been switched off and the MX2314 cannot scan to the higher SMB scan security level?
    Am I right with this?
    Would a MX2614 work?
    We are having to swap it foc as its part of a large contract, so hoping a MX2614 will work or a MX2640 if needed?
    Please help?
  • mansart
    • 855
    Re: MX2314 - NETWORK SCANNING
    MX2640 will only support SMB ver 2
    You could (if allowed) run a ftp service to accept scans to folder.
    • mojorolla
      The Wolf
      • 2630
      SMBv1 was dumped in 2014 so it is doubtful this is the root cause 7 years later.
      Check your job log for the specific error code. Generally, the folder path, username or password has changed. The error code will point you in the right direction.
      • onetek
        • 318
        I have a few 2640,3140,4101,4110... that smb scanning stopped working. Ended up using old Network Scanner Lite from Sharp which basically sets up ftp scanning...
        • RascalMJ
          • Mar 2009
          • 174
          I have started using this as well, in more difficult places or where it sees to get "broken" frequently. It works pretty well, is quick and easy
