Sharp mx 4070N good box?
  • davebtech
    • Apr 2015
    • 176
  • kdr363
    • Apr 2019
    • 63
    Re: Sharp mx 4070N good box?
    Supplies don't usually get their rate life, especially fusers. It's better since the toners was updated to MX61NT** from MX60NT**, but still not great life from supplies. Other than that, it's a fair machine.
    • timroz
      • Oct 2020
      • 18
      I work on this family every day. They are pretty good in my experience until around 600k+ impressions. Fuser's don't seem to last as long as they should, but everything else holds up pretty well.
      The way the erase lamp is oriented seems to collect toner so I often see ghosting. Usually I clean it and can extend the life of the process unit for a while.
      All things considered, its one of the better machines in Sharp's current line up.
      • Dark Helmet
        • May 2009
        • 854
        They added a toner scatter sheet to protect the blanking lamp and the new style drum frames has a larger cut in the mylar to also help protect the lamp. Always check the lamp when you have the drum out.
        As to the OP:
        The 70 series had it's teething pains, the higher S/N machine the better. Pretty much everything in the engine got a update. DV boxes, fuser, drums, transfer belt all had mods. the 71 series seems pretty solid now all the bugs have been fixed. That being said my low volume 70 series are just fine.
        We saw alot of drum blades fail due to age. The newer blades seem fine. Early fusers were crap. I rebuild the 70 series fuser with the 71 belt and LH. Works fine. The longer life supplies (when they make it) has definitely reduced service calls. Not an amazing machine but they work good enough. The predecessor MX2640 was a great little box. I'd say this line is comparable to it.
        • davebtech
          • Apr 2015
          • 176
          As to the OP:
          Thanks all ,good info. Dave
          • ridgemill
            • Sep 2017
            • 190
            We have had a few of these machines (as well as most of the Phoenix & Griffin range) fail when ejecting toner carts, causing a F2-9X. Might be prudent to keep a scrap machine, or a spare toner motor drive assembly in stock.
            You can get the customer to run Toner Eject from Settings, and use a pen to just force out the carts. Or, running toner eject multiple times sometimes works.
            Make sure when replacing the waste container, that the customer does a few pressed on either side to make sure it is fully seated. Have had a few drum locks caused by waste toner backing up from the front of the drum unit.
            All this should apply to the entire Phoenix/Griffin/CR4.5 range.
            • Toner Boy
              • Aug 2007
              • 366
              Check fuser separation plate for buildup every call. It's pretty easy to take out and clean, causes rubbing noise and potential damage, good PM measure
