MX-3114N Color Mode Enable
  • urmunet
    • May 2024
    • 5
    Hey guys
    I have a Sharp MX-3114N copier machine. Recently I faced F2-41 error code related to Cyan density sensor. I decided to temporary disable color printing to continue print BW. It works good. I did it from web management > enable / disable settings. Now I want to enable color printing again, but that checkbox disappeared! I will appreciate anyone can help me to find and enable it again.
    Thanks in advance
  • chatkal
    • Aug 2015
    • 47
    Are you sure you disabled color printing? As far as I know you can disable color printing on PC only. (in printing preferences)
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 696
      Pretty sure the setting you found is only when printing from a phone, if it was under System settings > Printer Settings. That doesn't do anything to stop it from printing color.
      • urmunet
        • May 2024
        • 5
        Yes I'm sure. There was a checkbox in web management > enable/disable settings. I've checked the disable color mode but now it's disappeared. I read somewhere once disabled this option, only a technician can enable it!
        • urmunet
          • May 2024
          • 5
          Here in this link you can find: https://business.sharpusa.com/portal...nts/07-041.htm
          • vigour
            • Aug 2010
            • 1038
            that is wild
            I would have loved to be able to disable so many options when I was working
            • Hart
              • Feb 2024
              • 406
              "This function is only for use as an emergency measure. Once this setting is enabled, only a service technician can cancel the setting. Promptly contact your dealer or nearest SHARP Service Department listed in the Quick Start Guide to have a service technician cancel the settings and resolve the problem."
              Well I don't know how I'm supposed to do it as a service technician ...
              • ihatefinishers13
                • Feb 2020
                • 696
                Never even heard of it... Just replace the machine, it's End of Life anyway
                • urmunet
                  • May 2024
                  • 5
                  Even there is no any warnings to notify user before doing it!
                  Anyway BW printing and all other functions except color printing are working well...
                  • ridgemill
                    • Sep 2017
                    • 190
                    SIM 14 clears this setting
                    • JLSam
                      • Jun 2015
                      • 605
                      +1 Rep if I could.
                      Can confirm disables color mode.
                      • urmunet
                        • May 2024
                        • 5
                        Thanks dude, it worked! Now the checkbox shows again.
                        For those who didn't know about this option here can check below image I marked the address.
