bypass tray CR5 options
+ More Options
Posts
  • boutn
    • Jun 2016
    • 547
    Hello all,
    what do the highlighted options do exactly?
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 710
    When [Enable Detected Paper Size in Bypass Tray] (disabled by factory default) or [Enable Selected Paper Type in Bypass
    Tray] (enabled by factory default), which you can reach by selecting [System Settings] in "Settings (administrator)" ? [Printer
    Settings] ? [Condition Settings] ? [Bypass Tray Settings] is enabled, printing will not take place if the paper size or paper
    type specified in the printer driver is different from the paper size or paper type specified in the settings of the bypass tray.
    Exclude Bypass-Tray from Auto Paper Select
    When [Auto] is selected for paper type selection, the bypass tray is excluded from the trays that can be selected. This is
    recommended when special paper is often placed in the bypass tray.
    Factory default settings: Disable?
