Sharp AR5520 Dumping developer
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    SHARP AR5520 Series.
    Cleaned charge corona, transfer corona, put fresh developer, ran the developer simm, changed drum
    the copy comes out with lines of developer or jams right at drum area.
    I know is a HV leak somewhere, any ideas?
    See photos.
    update--****photos are not uploading, site problem.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Sharp AR5520 Dumping developer
    Finally I was able to upload the photos:
    • OlliK1969
      • Nov 2016
      • 310
      Hi
      hot roller gear ?
      when it is broken or mad, it make jams like your photos
      • Toner Boy
        • Aug 2007
        • 365
        I'm going to assume the developer unit seal above mag roller is good/new, not digging into DV?
        Drum unit swap, if available.
