Sharp MX M316N F2-40 toner sensor range malfunction after pm, new drum and developer
  • tonerjockey
    • Apr 2014
    • 567
    Hello, the calibration seemed to take a while and fluctuate.
    3 weeks and 3000 prints later it threw F2-40. i checked sensor, developer and all looked fine. reset and ran 100 copies. toned back up by itself.
    another week later, same code.
    i am going to change the toner today and order another developer.
    am i missing anything??
    thank you a bunch.
  • tonerjockey
    • Apr 2014
    • 567
    and i just discovered that they are now using " for use in" toner, that says "made in USA"
    so i ordered a OEM developer and toner and will install that tomorrow.
    darn thing.
    have a nice day.
    • tonerjockey
      • Apr 2014
      • 567
      ok, after several days for a one day ship, due to vendor putting my company name instead of the customers on the parts. i also realized that the customer has been telling me, it keeps jamming. and then i go there and find the F2-40 error code.
      so i took a ATC toner sensor from another machine there that recently had a different problem and put that in this one with the new developer and OEM toner.
      with luck this will resolve the issues.
      fingers crossed.
      • bilyahn
        • Dec 2006
        • 1470
        Good luck. I have had a lot of F2-40 problems lately due to aftermarket toners.
        Bil
        • tonerjockey
          • Apr 2014
          • 567
          Hi bilyahn, ok, thank you. this makes me more relieved that i may have been able to resolve the problem. i told them, cross my fingers and i knocked on the wood paper cuter. then thought, with all my years sweeping developer, there really should be no mystery. but the next possible causes start to become expensive.
          • WackyJack
            • Feb 2021
            • 82
            Not the same model, but I recently had F2-40 codes that were being caused by the PCU PWB
              • 23008
              It's been a long while since I worked on Sharp (there's my qualifier), but ...
              There were several models of Sharp that did not do an adequate developer stir on the first try. I always shake the developer well, and that is still not enough. I became aware of the desired stir numbers (sorry, don't remember those numbers anymore), and if I got a value outside of the desired range I would stir again, and sometimes a third time, until the number looked good.
              I think you've identified the main issue with the aftermarket toner, but without a complete developer change and vacuuming out the hopper, it will take a while to work through the residual aftermarket toner.
              I seem to recall the Panther and Andromeda series were known of low developer stir values. That shows you how long it's been since I've worked on Sharp, lol. =^..^=
