sharp mx-c357F is printing too light
  • Copyguy69420
    • May 2024
    • 45
    i have a sharp mx-c357F is printing too light. i tried changing the drivers and it is still having the same issue. I tried printing on my office copier and notice a difference. The canon copier is darker than the sharp copier. they can scan and copy fine. What other settings can i change?
  • bilyahn
    • Dec 2006
    • 1470
    It is unusual for it to be printing lite but copying just fine. Did you try changing the toner? I believe this is a lexmark/sharp so that might do the trick. What does your supplies report say and how does the copy density look on the report.
    Good luck
    Bil
    • Copyguy69420
      • May 2024
      • 45
      Their old toner was running low so they changed the toner. And where would i check the copy density and where would i find it?
      • mloudy
        • Oct 2015
        • 790
        Best way to check copy settings is through the web interface. Settings, Copy...Content Type, Temperature, Darkness. There are also Advanced Imaging settings there.
        • JLSam
          • Jun 2015
          • 605
          Posting on the Lexmark forum might give you better answers. :\
          Also, check make sure toner save mode is unchecked.
          Now, I'm not sure if this Lexmark Reboxed MFP has the same simulations as a native Sharp, but Sharp "light Prints" are generally REALLY easy to solve.
          Clean LSU windows, chargers, PTC, IDS, Drum Discharge lamp.
          Developer, TC2, Drum, Charger, with calibrations 25.2/ 44.2/ 44.6/ 44.27/ 44.26/ 61.13/ 61.11 (L, M, D)/ 46.74
          Good luck!
          • boutn
            • Jun 2016
            • 547
            Its a lexmark...just put the 'toner darkness" to 5 and its good to go...
            settings - print - quality - toner darkness
            • Copyguy69420
              • May 2024
              • 45
              i will try that and let you know.
              • mloudy
                • Oct 2015
                • 790
                We set the copy Darkness to 6 on all Lexmark & Sharpmark machines before they are installed.
