MX-B355W - Scan to One Drive
  • MHeon71
    • Oct 2008
    • 489
    I have a customer that is trying to scan to One Drive. He has active directory and a card reader. The card reader is working, because he can login, but he then needs to log in for the One Drive which fails. Has anyone dealt with MX-B355W scanning to the One drive and is there something I am missing?
    He has set this up on MX-3071 type machines and they work fine. The web interface between the 2 types of machines does not have all the same sub categories between the 2 types of copiers, so I am not sure if we are missing something.
    Thank you for any help.
  • timelmrep05
    • Feb 2018
    • 13
    Hi.. I'm pretty sure the device will need an expansion kit for One drive to work.. The Mx3071 will have that as standard
    • MHeon71
      • Oct 2008
      • 489
      Thanks for the info. The only thing I think it could be is the MX-AMX1, but I am not sure. I will look into it.
      • OlliK1969
        • Nov 2016
        • 310
        Hi, you also need a firmware update version 4.02 or higher.
        Quote Sharp:
        Correction of the trouble that the login to Google Drive Connector/ Gmail Connector may fail.
        • MHeon71
          • Oct 2008
          • 489
          It is at 4.04. Flashed last week.
