sharp ar-161 copier
  • mireb
    sharp ar-161 copier
    my copier keeps flashing L-6-L-6 etc. any suggestions on what is wrong or a way to reset? thanks
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    if you cycle power to the machine it'll try to clear itself. Hold the start button down for the sub code. L6-01 it's main motor lock. L6-10 is the polygon motor. Either way it's not something you can fix.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • mireb
      Tmaged:
      Thanks for your reply The subcode was 10, so it looks like I'll have to take it in to be fixed.
      • tmaged
        • Oct 2008
        • 1885
        Yep, L6-10 means the motor inside the laser unit has failed. If cycling power doesn't clear, then it will need replaced.
        Hope that helps !
        -Tony
        www.dtios.com
        • swagreis
          • Jun 2008
          • 92
          it is L6-10 polygon motor fail
          the part no. is RMOTN0022Q
