E7-03 HDD replacement
  • ron67601
    • Apr 2024
    • 19
    I had a MX-4051 that had a E7-03 code. I backed data up with 56-02, then replaced the HDD with a new one. I imported the data back into the new HDD and that all worked. But when I go to do a 22-6 or a 64-5 it doesn't print anything out. Am I missing something? I also installed the watermark again even though it didn't give me a code. Please help. Thanks Ron
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 707
    I would think the mSata is probably failing. Could also try to do a CN Firmware update, takes a while but could save you some money. If you need the info from the 22-6 in the meantime, at least you can export it to USB.
