old Sharp MX-M354n Firmware
  • Service@PRT
    • Oct 2016
    • 181
    Good day everyone,
    We encountered an issue where a client machine unexpectedly restarted and is now requesting firmware. Given the age of the machine, finding the appropriate firmware might be challenging. Before visiting the client, so i try here to locate the necessary firmware.
    If anyone still have firmware for this old machine, will highly appreciate it.
    thank you
    This gallery has 2 photos.
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • Hansen88
    • 1084
    Originally posted by Service@PRT
    Good day everyone,
    thank you
    I never have seen a message like that. The only time I have seen that is if the emergency firmware update procedure is being performed. Is it possible someone else was messing with it?
    • Doug.P
      • Aug 2015
      • 63
      There are 2 firmware updates for this model from 2018 one for machines with an HDD and one for machines without HDD I have attached both good luck. also it does look like the machine is in CN update mode(emergency update) which should only show that screen when a DIP switch is flipped on the MFP PWB CAPRICORN_COMW:HDD:BI_0501C1L0_B.ZIP
      CAPRICORN_COMW:O HDDBI_U500C1E0_B.ZIP
      • Service@PRT
        • Oct 2016
        • 181
        will know if someone touch it when i visit.
        Thank you very much!
