Mx2310U E7-20 code
  • triplejim
    • Sep 2021
    • 3
    [Error Code] Mx2310U E7-20 code
    Afternoon, I've read this post (and others) on E7-20 errors:
    https://www.copytechnet.com/forums/s...-mx-2310u.html
    Work to date, entered simulation mode:
    -Cleaned the LSU dustproof glass
    -Cleaned the PTC wire
    -Image adjustment Sim50-22, adjusted clicks, two were (NG), now have three (ok)
    -LSU test Sim61-1 (test ok)
    -Remove and refit DC supply cable at both DC PWB and LSU PWB
    -Taking drowrangers advise in the above linked post, checked the dc pwb to lsu (CN104 pin 1). Voltage was 5.15vdc (ok)
    Later, the machine presented the error and the voltage was 4.97vdc (hence intermittent fault)
    After 15 seconds of warmup, the voltage increased to 5.15 so I restarted the machine and message gone.
    Is it possible to adjust a parameter to allow 4.9vdc or similar?
    Or is this a case of replacing the board?
    Many tks for reading, James
  • copiertec
    • Jan 2016
    • 2206
    Re: Mx2310U E7-20 code
    Is it the latest firmware? If I recall Sharp had come out with firmware to correct the E7-20 issue almost 10 years ago.
    • triplejim
      • Sep 2021
      • 3
      Mx2310U E7-20 code
      All Custom Setting List printed in 2013 lists NIC firmware version 01.05.00
      All Custom Setting List printed today lists same NIC firmware version 01.05.00
      Ive emailed Sharp to ascertain if NIC firmware version 01.05.00 is this the latest firmware version
      Tks, James
      • copiertec
        • Jan 2016
        • 2206
        Yes, that is the latest firmware (0700G1io), although I am not sure about the NIC. Is the wall AC voltage good?
        • triplejim
          • Sep 2021
          • 3
          Mx2310U E7-20 code
          Correction, was reading the software section, the hardware firmware versions are:
          ICU (MAIN): 07i00.G1 (previous was 06.01.G1)
          ICU (BOOT): 01.03.G1
          ICU (SUB): 01.09.G1 (previous was 01.07.G1)
          PCL (MAIN): 05d00.G1 (previous was 01.00.G1)
          PCU: 03.09.G1 (previous was 03.05.G1)
          SCU: 01.07.G1
          Our voltage at the wall is 240.6VAC
          For years, it was much higher but they adjusted the transformer due to solar panel output in the street.
