Sharp MX-3051 bad quality prints
  • iglicar
    • Oct 2019
    • 6
    Hi guys,
    Anyone has seen this before? It's not coming everytime also if i re-enter SIM 64-5 it looks good and then re-eneter again it looks bad...
    We have tried new transfer, secondary transfer, TC PWB, MC PWB, All drumunits. When i stop the print and check transferbelt the picture looks bad there also.
    Thanks.
  • OlliK1969
    • Nov 2016
    • 311
    Hi, I'm assuming that you have cleaned the optics including the CCD unit and laser. What happens if you do 50-22 and then run 46-74? It would also be interesting to see how much the device ran in color/black and white. The MX-3640 used to have an error that the SD card was defective. But as I said, more information wouldn't be bad. Did the error occur suddenly or after maintenance? Questions about questions
    It could also be that the calibration sensors are dirty. Service Manual 4-13, there are 2 that need to be cleaned
    • iglicar
      • Oct 2019
      • 6
      Error occur suddenly, yes cleaned up everything also the calibration sensors and did a full calibration.
      Color: 61 000 BW: 94 000
      • MHeon71
        • Oct 2008
        • 489
        The paper seems wavy, does the paper feel damp? On 1 machine, I believe a MX-4070N, I use to get C4 errors and CQ. The outer PTC housing was cracked, it is hard to see, but a new holder resolved the issue.
        • havokprod
          • Oct 2012
          • 159
          I've had something similar happen to me a few times, secondary transfer roller was not reaching full extension. Clutch in the main body cluch pack responsible for this action was dirty. Good luck, let us know what it was.
          • AlexandruMG
            Service Engineer
            • Jul 2024
            • 14
            Hi mate,
            This looks like poor transfer from drum unit to transfer belt do to a mechanical or high voltage issue.
            Try to print a test chart in multiple copies and jam the machine in order to see how information looks on photoconductor drums and primary transfer belt.
            Dont forget to let us know the results.
            Regards,
            Alex
            • iglicar
              • Oct 2019
              • 6
              Hi
              Just let u know that replacing the clutch like havokprod said was the problem!
              Thanks everybody.
              • Kenny
                • Jun 2009
                • 526
                Would you happen to have the part number for the clutch? just for future reference
                • iglicar
                  • Oct 2019
                  • 6
                  PCLC-0402FCZZ
                  Number 25 in fusing drive
