bad Magenta fill on BP-70C55
  • driving lots of miles
    • Jun 2016
    • 403
    I am getting a bad Magenta fill on BP-70C55. All the other colors are solid fill. There are 18,000 black copies and 55,000 color copies. Machine is almost a year old. I have cleaned contacts on all the drums and developers. I have replaced the magenta drum unit with a brand new complete unit. All optics have been cleaned. When I try to do auto registration I end up with ERROR: DATA_SUB_K_F_2nd 11. I have tried to do the registration thru system settings and thru Sim 50-22. We are using genuine sharp toners. Any ideas would be helpful. Thanks
  • harps05
    Field Service Engineer
    • Mar 2012
    • 114
    Had this the other week. I had to add a new dev to it. Not sure why though.
      • Jun 2016
      • 403
      Thanks, that was the next thought I was tossing around but wanted some input as it is way early for developer.
        • Jun 2016
        • 403
        The solution was to replace the magenta developer.
        Thank You harps05
        • harps05
          • Mar 2012
          • 114
          I had to do the Magenta also. I changed the drum unit at the same time, to be sure. Yesterday, same machine, same problem this time Yellow dev.?.?
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            There was a bulletin relating to developer pull (not sure if this your issue) and to check the blank lamps were in the correct position, this would cause lack of drum quenching and result in low dev quantity.
            Networking skills are advantageous but use of a 3m vacuum cleaner is essential
            • Chr15tophe
              • Dec 2011
              • 42
              Do you have that Bulletin ref ? thanks
              • Chr15tophe
                • Dec 2011
                • 42
                Theres modified dev units for these machines..
                • odinp
                  • Jun 2019
                  • 35
                  I have fixed this issue by running 25-02
                  • OlliK1969
                    • Nov 2016
                    • 312
                    Hi
                    When the developer is out of the unit, he's gone. With 25-02 you fill up with toner for a short time and mix everything well, but the error will come back in the short term.
                    • Massimo
                      • Feb 2023
                      • 22
                      Scusate , basta sostituire il developer magenta o bisogna sostituire anche il gruppo di sviluppo? Io su una bp70c55 mi da F2-42
                      • nanohitmen
                        • Apr 2019
                        • 118
                        these machines suck, have gotten a few bad batches. We had to stock up on the new DV units cos we got soo many bad machines straight from sharp. also the fusers suck ass on the BP's
                        • ihatefinishers13
                          Senior MFP Technician
                          • Feb 2020
                          • 726
                          You're not wrong. The early fusers are garbage, and Sharp should lower the price on the new ones for a while or something. They're way too expensive for how many problems we have with them. The new ones so far have been fine, but we haven't had a single fuser last to the expected 600k life. Not. Even. Half.
                          • miller01123@gmail.com
                            • Jun 2019
                            • 57
                            Have you checked for clumps in the toner bottle?
                            • Massimo
                              • Feb 2023
                              • 22
                              Il toner è originale , ho ordinato il gruppo dv magenta e developer magenta appena mi arrivano li cambio ( nel frattempo è uscito un bollettino che hanno cambiato i gruppo sviluppo).
                              Il motore che muove il flacone toner funziona
