mxc301w - scan to email
  • Kenny
    • Jun 2009
    • 529
    hi guys,
    got a pain in the ass MXC301W that will not scan to email,
    we have updated firmware so can use TLS 1.2 triple checked the device settings (they currently have a Konica C3350 on site that works fine with the details)
    never seen the smtp server address the customer uses - smtp.ionos.co.uk
    the settings have just been copied across from their Konica machine
    we have followed the attached bulletin with regards to added <> in the sender address and inputting the sender address via image send settings SolBulletin-89-Scanning-to-office365.pdf
    any ideas? or can this machine not use the certain smtp server address?
  • yurisan
    • Dec 2007
    • 118
    You could have several issues - encryption level set too high or too low in SSL settings, sender name field is empty, sender name field conflicts w/ authentication credentials sender that is set in Scan Settings.. This email server may be looking for a verifiable return email address. If you are getting a CE-00, the server most likely was contacted/addressed by the Sharp, but rejected, and the reason is usually syntax or programmed credentials that don't line up.
    • Kenny
      • Jun 2009
      • 529
      so i have set the encryption strength to middle, do you need the sender name? i usually leave that blank, the current error is CE-00 and in the job log its error 80-0000
      as i say the other Konica machine works perfectly fine so dont really understand as to why it doesnt work
      • yurisan
        • Dec 2007
        • 118
        Yes, the email server may require something in the sernder name field - Microsoft's certainly does.
        • Kenny
          • Jun 2009
          • 529
          oh my days.... i thank you sir! it now works
