Curl Adjustment
  • boutn
    • Jun 2016
    • 540
    Curl Adjustment
    Where can i find some info on the Curl Adjustment option in the service login/paper settings section.
    And what does the Fuser Pressure Setting do? It only has 0 or -5
  • Hansen88
    • 1053
    I have not run into those adjustments before so I dont know. I wish they explained all the adjustments better. May have to do trial and error and see what happens.
    • Michko
      • Sep 2010
      • 31
      I would love to know too
      I made a paper but cannot find it anywhere.
      • bilyahn
        • Dec 2006
        • 1470
        Sharp used to have web interface training on their IDNC tech site but that was many years ago when the new (current) interface came out. It went through each screen step by step so might be something to look into to see if it is still there and has the information you are looking for.
        Good luck
        Bil
        • tmw
          • Dec 2013
          • 256
          I haven't seen that page before. I have made temperature changes in the sim selection. I wonder if on the BPs is like on the phoenix 30/4070s etc. The output rollers have foam circles that have worn out or become compromised some way. Check if those need replacement.
          • boutn
            • Jun 2016
            • 540
            Thats not my question...and yes, you can also do this with the CR4 / 4.5 but the options are different, and i don't know what those options do either
