Network trouble.
  • Hansen88
    • 1068
    Network trouble.
    Customer has three machines side by side. This one wont print, email ect. In the pic I am showing, it shows the IP, but to the left it shows a IP starting with 169. If I unplug network cord and reboot machine I can print connected to my laptop and both IP"s match. Plug back into the network and then the 169 shows up. The other two machines are working. To me it seems like a network issue on their end. What do you think could be going on? Network side of things I am not real strong on.
    • 23008
    Can you reach another network connection/port to test, or roll the machine closer to another network port? I agree, it sounds like that network port is non-functional. =^..^=
    • WackyJack
      • Feb 2021
      • 82
      We disable mDNS and that usually stops machines from pulling those ZeroConfig IP addresses
      • OlliK1969
        • Nov 2016
        • 311
        There is a network problem. Either the connection is defective or not switched. But the problem is definitely not with your device
        • Hansen88
          • 1068
          Thanks for the replies. I showed the customer and they are going to have whoever does their IT look at it. I am mainly trying to find out for my knowledge.
          • bilyahn
            • Dec 2006
            • 1470
            I would plug one of the other machines into the same port to see what happens. If the IP is zero conf then it's definitely their network! Easy way to prove it's their network and not copier issue..
            Good luck.
            Bil
            PS Did you try a different Ethernet cable by chance?
            • FinishersSuck
              • Nov 2024
              • 3
              My guess is that the network outlet in the wall is not patched.
              An easy way to troubleshoot is to either plug a laptop to the network cable connected to the machine and see if you get internet / network or just try one of the working machines on the same cable.
              • mojorolla
                The Wolf
                • 2616
                Learn how to create an "ad-hoc" network with your laptop. Modern devices no longer need crossover cables so any cable will do nowadays.
                Anytime I have a suspected network issue, I configure to my laptop then print and scan while the customer watched me do so.
