BP60C31 dumping Toner on LSU
  • Larhal
    • 583
    Ok So I had to go back to work part time as I cannot afford to be retired. So I am working on a Sharp BP60C31 which has toner dumping on the LSU. Mainly cyan and magenta. The toner is Original Sharp BP70GT Toner and these are the original processing Units as there are only 125K pages on the clock. So I removed the magenta and cyan process units and found them leaking waste toner from behind the centre of the cleaning blade. It seems that Sharp did not put a screw and nut at the centre hole of the cleaning blade and the housing warped slightly causing the gap.
    So I went to the parts manual and there is no part number for a complete Processing Unit.
    Can Anyone help me with this as I want to change all of the imaging units.
    TIA
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • Larhal
    • 583
    I believe I found it, BPDU70SA
    Larhal
