MX-3570 has H3-02 wont reset
  • Hansen88
    • 1053
    Hello, this machine goes into this code as soon as machine is turned on. We have replaced the fuser, pcu board and the ACpwb. None of thesr have changed anything. Seeing if anyone else has any suggestions on what next. Thanks
  • ridgemill
    • Sep 2017
    • 182
    Check the harness inside the machine for dirty/bent pins.
    • Hansen88
      • 1053
      we also just swapped the fuser connection harness inside the machine. Still no good.Nothing mentions the mfpc board, but that is about the only thing we have not replaced, dont have one. We have dealt with this code before, but non of what fixed it before works on this one.
      • tmw
        • Dec 2013
        • 256
        It changed from H3-02 TO H2-02. Also changed the fuser drive.
        • Hart
          • Feb 2024
          • 366
          Found this
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 664
            Originally posted by Hart
            Found this
            Oh definitely this. A bunch of times that gear has failed and need replaced, so we just stock that gear/shaft.
            • Hansen88
              • 1053
              We are still stumped on this one. We have replaced the PCU board, AC pwb, HL board, multiple fusers, fuser connection harness. The code pops up right away before the machine pre drives or anything. Also we changed the fuser drive a couple times, parts from a working machine. Also did firmware. Thanks for the replies so far and any new ideas I will sure appreciate.
              • ihatefinishers13
                • Feb 2020
                • 664
                Have a sales rep upgrade them :P if only!
                • Hansen88
                  • 1053
                  Right!
                  • Hansen88
                    • 1053
                    Seeing if these pics mean anything , problem machine showing 0 degrees in Thermistor sub 2, I am not sure what sub thermistors are? Are they the non contact thermistors? The fuser is good, I put it in another machine and the other pic shows degree readings.The PCU board we just got from Hytec, I put the original back on and no change in the readings.
                    • ihatefinishers13
                      • Feb 2020
                      • 664
                      Did Sharp Tech Support say anything regarding the sub thermistors? I can't find what they are either.
                      • Hart
                        • Feb 2024
                        • 366
                        I'm pretty sure that the sub thermistor is the flimsy piece of shit at the right edge, in contact with the fusing belt.
                        RDTCT0250FCZZ
                        TH_UM : main center non-contact
                        TH_US1 = TH_US : edge non-contact
                        TH_US2 = TH_SUB2 : sub edge piece of shit
                        But the manual says it's the edge non-contact
                        H2-02 Thermistor open trouble (Upper Sub TH_US1 detection) TH_SUB2_2
                        • Hansen88
                          • 1053
                          No, they were not much help at all.
                          • Tom54
                            • Feb 2013
                            • 8
                            DC PWB
                            • Dark Helmet
                              • May 2009
                              • 835
                              When you replaced the PCU did you follow the procedure in the book to calibrate the thermistors? You have to power the machine on and off with the fuser not installed or something.
                              Maybe also go into the fuser sim and reset the settings back to default incase some one was screwing around in there. Sim 43 i think.
