mx-m6070 with a 44-6 error.
  • bigdaddyooo
    • Dec 2014
    • 211
    Everything looks good. 44-2, 27, 26 and then 6 will error out. I cleaned transfer roller, reseated both connectors to R door and checked the 44-2. Everything looks good. This is stumping me. obtw, it did have a F2-74 RECENTLY. Then when performing a 46-74, it goes right into an F2-40
    Are you the police? "No ma'am, were musicians"
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 694
    How does everything look when printing? Could also try a DV spin(25-2), and see if that helps. I have also not been able to get 46-74 to work, and end up doing them separately with 46-24, and 67-24.
    • DAKOTADAN
      • Jan 2011
      • 61
      How many prints are on the machine, if its a early serial# and has over 200k on it I have had to change the transfer roller assm. the drum frame, new drum, and developer, and a complete new dev. unit. to get these codes to stay away. The transfer assm. drum frame, and dev. unit have all been updated, they stop dusting the toner sensor in the transfer assm. which pulls dev. , and gums up the fuser , which wraps paper. If I changed only some of these items the problems come back. Since changing all them items, now I can reach my pm's life expectancy. Good luck Dan.
      • bigdaddyooo
        • Dec 2014
        • 211
        DAKOTADAN Found out tech before me installed mx 560 parts and NOT the mx609MC and CH causing issues.
        • WackyJack
          • Feb 2021
          • 82
          I always use the MX560MK on these machines and never have any problems with copy quality or the items making life. I started using them when the MX609MC was always backordered, and I couldn't wait months for them to be delivered. Occasionally, I will get a machine that will not complete the 46-74 until I run through the 44 SIMs and reboot the machine a few times, but the other SIMs don't have any issues and always complete without error
          • bigdaddyooo
            • Dec 2014
            • 211
            interesting!!!
