Sharp/Lexmark
  • jon jennings
    • Aug 2011
    • 51
    Sharp/Lexmark
    Well now that I am Lexmark tech (it says Sharp on the front) I do not know how to get into the diagnostics of these machines. Any help would be appreciated.
    • 23010
    Re: Sharp/Lexmark
    Do you have access to manuals? What models are you working on? =^..^=
    • Prints Charming
      • Aug 2019
      • 189
      Re: Sharp/Lexmark
      Diagnostic Menu: *, *, 3, 6 from Ready Status, or Hold buttons 3 & 6 from Power Up.
      Safe Mode: Hold Buttons 6 & 7 from Power Up (allows use of device even with an error condition).
      Invalid Engine Code: Hold Buttons 3, 4 & 6 from Power Up (allows access printer webpage to perform update of firmware).
      Lexmark codes have been the same for many years. Works on the Sharps too.
        • 8348
        Re: Sharp/Lexmark
        ... hopefully, the same with Toshiba/ Lexmarks aka Toshmarks.
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: Sharp/Lexmark
          2-6 does something too. Clears counts, etc I believe
          • ZOOTECH
            Senior member of CRS
            • 3378
            Re: Sharp/Lexmark
            2-6 is Configuration (#2 key on your number dial), not sure about counter clear; 3-6 is Diagnostics (#3 key on key pad)
            Nice to know the other power on sequences by Prints Charming
            • oscarconil
              • Oct 2021
              • 27
              Re: Sharp/Lexmark
              Does anyone know if you can change the shortcuts of the first screen. in the lexmark it is possible, but in the sharp it is not possible
              Thank you
                • 23010
                Re: Sharp/Lexmark
                You can make selection of what icons appear during the initial setup wizard. If you want to make different selections you must re-run the initial setup wizard. =^..^=
                  • 8348
                  Re: Sharp/Lexmark
                  Thank you
                  From the web browser: Settings/ Device/ Home Screen Icons
                  • oscarconil
                    • Oct 2021
                    • 27
                    Re: Sharp/Lexmark
                    I say the home screen where it appears easy copy, easy scan, easy fax
                    I can't modify
                    a come out
                    • mloudy
                      • Oct 2015
                      • 791
                      Re: Sharp/Lexmark
                      What exactly are you wanting to add or remove from the home screen?
                      • boutn
                        • Jun 2016
                        • 552
                        Re: Sharp/Lexmark
                        The FAX maybe?
                        Or add scan to folder locations?
                        Or anything else that we do on the bigger machines...
                        • mansart
                          • 855
                          Re: Sharp/Lexmark
                          I don't believe the initial screen on the Sharpmarks is customizable.
                          It is simply window dressing to hide the fact that it's a Lexmark.
                          The screen you arrive at when pressing "Advanced" is the Lexmark home screen I believe and this is customizable .
                          • mloudy
                            • Oct 2015
                            • 791
                            Re: Sharp/Lexmark
                            I tried some things and for now I don't think the splash screen can be altered. I have seen Lexmark built Konicas and they have their own unique operation panel that looks like a Konica OP.
                            The Sharpmark home screen may give the user the impression that it is like the other Sharps in their office but once they get past the home screen they are left to fumble through Lexmarks clunky screens.
                            I went to the apps and disabled the Fax app. Many users don't even use their machine as a fax. I was hoping this would remove the then useless Easy Fax icon but it didn't. Very dumb.
                            Here is the problem with any Mfgr rebadging things. We have been selling the Lexmark version of the MX-C407F for 5 years now. We now have a MX-C407F in the shop that throws Firmware Error 900.00 every day. It's firmware is the most current that Sharp offers which is TWO firmware version behind where Lexmark is at. The newest version of Lexmark firmware for this model addresses the issue of? You guessed it, 900.00 Firmware errors.
                            • ricohrice
                              • Dec 2008
                              • 42
                              Re: Sharp/Lexmark
                              The default screen on the Sharpmarks can not be edited in any way according to tech support
