Sharp MXM 905
  • Clone
    • Oct 2021
    • 19
    Sharp MXM 905
  • mojorolla
    The Wolf
    • 2606
    Re: Sharp MXM 905
    I believe the 905 had the dip switches on the MFP board to reset admin password...
    • Clone
      • Oct 2021
      • 19
      Re: Sharp MXM 905
      • Prints Charming
        • Aug 2019
        • 189
        Re: Sharp MXM 905
        MXM905 needs admin password reset completed by the admin password reset form, obtained by your local tech specialist.
        MXM904 had the switches on the MFP Board to manually reset the admin password.
        • Clone
          • Oct 2021
          • 19
          Re: Sharp MXM 905
          Yes. But I think someone can share the file with me.
          • Clone
            • Oct 2021
            • 19
            Re: Sharp MXM 905
            I know but i think someone can share the file with me.
            • Prints Charming
              • Aug 2019
              • 189
              Re: Sharp MXM 905
              If you cannot obtain the file, backup the address book and network settings only in Device Clone Settings, then perform Private Data Initialize in Security Settings. Once the device is returned to factory, restore the 2 clone files you made earlier.
              Your admin password will be restored.
              For the time it takes to run the device reset & HDD format, it'll be quicker than waiting for a file that may never come.
              • havokprod
                • Oct 2012
                • 159
                Re: Sharp MXM 905
                Don't you need the admin password to get to the Private Data Initialize in Security Settings?
                • Prints Charming
                  • Aug 2019
                  • 189
                  Re: Sharp MXM 905
                  Ah yes. Ignore this idiot who was clearly not thinking!
                  Forget what I said.
                  Format the HDD in 62-01. That should work too.
                  • havokprod
                    • Oct 2012
                    • 159
                    Re: Sharp MXM 905
                    Forget what I said.
                    I did not know that thanks for the tip.
                    • Clone
                      • Oct 2021
                      • 19
                      Re: Sharp MXM 905
                      If i format HDD,I would have a error u2-60 ?
                      • Prints Charming
                        • Aug 2019
                        • 189
                        Re: Sharp MXM 905
                        On older models, normally yes. However on the MXM905 the Watermark and OCR is stored on the mSata not the HDD.
                        See Page 423 of the Service Manual.
