Sharp MX-3051 toner can't detect
  • skyfong
    • Aug 2012
    • 18
    Dear guys,
    Did anyone know what is the reason of the Sharp MX-3051 toner Cartridge keep eject when the new toner plugin? The machine didn't show any error code but when plugin the toner - M, it keep eject out & show replace toner cartridge
  • timroz
    • Oct 2020
    • 18
    Re: Sharp MX-3051 toner can't detect
    We once had 3070 that a customer slammed the toner cartridge in and dislodged the Crum reader in the back of the toner slot. I don't remember the symptoms besides not reading the toner but worth a check. You can see it if you take the toner out and shine a light into the back.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Originally posted by skyfong
      Dear guys,
      • timroz
        • Oct 2020
        • 18
        Also, is this OEM toner? Could be a bad Crum chip. We briefly tried after market toner and had Crum issues.
        • Prints Charming
          • Aug 2019
          • 189
          The Toner Eject System operates under one of the following conditions:
          * Toner Empty
          * Non-Genuine or Improper Toner Cartridge has been detected (F2-70 etc)
          * Toner replenishment problem has been detected (F2-64 etc)
          * Toner Cartridge Error (F2-74 etc)
          * Toner Density Sensor trouble (F2-40 etc)
          * User via System Settings or Simulation
          Toner Eject System errors start at F2-95, but that is a problem with the Ejection Mechanism in the Toner Motor.
          The MX3051 does not have a Toner Hopper like the 50 & 60 ppm devices, so there's no problem there.
          If you are installing a Magenta cartridge and the device rejects the cartridge straight away, it's either empty, non-genuine or you have a problem with the Magenta Dev.
          Check Harness CN6 on the PCU board as this connects to all Toner Eject Units & Crum Chip connectors.
          • ZOOTECH
            • 3375
            Sorry, folks, I totally misread the model type - my apologies.
            • mabro1974
              • Feb 2013
              • 39
              [QUOTE=skyfong;1961470]Dear guys,
              Sounds to me like uptodate firmware and non original toner cartridge , maybe 3rd party compats. Latest firmware does that.
