All of the problems are in reference to checking all the boxes and copying all of the settings. Cherry picking one or two things, of course you'll have less problems. Dealers like to do it easy and copy everything, and then weird things *might* happen. Before the BP's, we rarely had any issues; usually it was when cloning a 2600 to a 2640 and then later cloning that to a 3070. One model to another, basically never had a problem, but multiple clones compounding over the years, definitely had some funky things happen. With the BP's, I haven't cloned anything because of all of the horror stories we've heard of from other dealers, our DSS, and people on here.
BP models Storage Backup and/or Device Cloning
There is a new firmware for the BP series that came out yesterday addressing this known issue. It is version 420Q1a0Are you the police? "No ma'am, were musicians"Comment
You can backup the Address Book and User Lists to CSV (also under System Control), but otherwise, there have been wayyyyyyy too many problems for me to ever clone, even if/when Sharp comes out with a way to do so. I'll be skeptical, for sure.
That being said, I've seen one dealer(during an inter-territorial install) copy over the network settings(mostly for SMTP and LDAP), and they haven't had any issues.... But it was 3 machines at one customer, so much too small of a sample size.Comment
I've cloned 70's and 71's to BP's many times now without any issues except for today.
On Storage Back up, I only use Address Book.
On Device Clone, I use: Network Settings, and Clock Adjust. That's it.
Then correct AIRPRINT settings, Device Name settings, and Static IP addresses.
Strange issue today though, for the first time.
MX-2651 to a BP-50C26
SMTP Auth would not "save". After checkmarking SMTP Auth, inputting username and APP pass, submit, update, the "SMTP AUTH" would go back to default none.
CN Update fixed this issue no problem.
First for everything I suppose.
Pretty sure is been fixed and re released.
You can use 56-9 to import address books from older models.
Ive never had any issue cloning Network setting and only network settings.Comment
I recently cloned an MXM754 to a BP70M65 and the only thing it messed up was the tray settings. Which was easy to fix but had to do it to 16 machines LOL I cloned all of the settings.Comment
