BP70C55 50-22 issues
  • sharphead
    • Aug 2009
    • 285
    I have a 70C55 that is running out of calibration regularly. I don't have another device to swap parts.
    Having changed the developer I still couldn't get a 50-22 to work. I've it running by a 50-20 but this only lasts so long.
    Any ideas?
  • DCStech
    • Dec 2024
    • 13
    I just ran into this and it was the transfer belt slipping. Will it take the other calibrations without erroring out? Also, what is the 50-22 doing? Is there an error code that appears such as a range 93?
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 716
      The only time I've seen this, we swapped the whole transfer unit (had a parts machine), and the problem never came back.
      • sharphead
        • Aug 2009
        • 285
        Thanks to the both of you. I never actually noted the error code on the 50-22. The 44-2 worked ok, the rest of the calibration seems fine after the 50-20.
        Great shout. I will get a new unit ordered and into it.
        • Craigcul
          • Aug 2017
          • 70
          hi there we normally stretch the springs that push the one roller out and that helps sometimes you have to take the belt off and clean the outer rollers as well.
          • sharphead
            • Aug 2009
            • 285
            I've fitted a new transfer unit, but still getting an error DATA_SUB_K_R_3ed 17
            Tried stretching the springs on this new unit, there is no slipping when turning by hand.
            Any other thoughts?
            • ihatefinishers13
              • Feb 2020
              • 716
              Any other thoughts?
              If you have another registration sensor unit to swap with, I'd try that. It's a 10 second swap and doesn't hurt anything. After that, I'm pretty sure it's PCU, but don't quote me on that.
              • ihatefinishers13
                • Feb 2020
                • 716
                Since you're able to calibrate manually, I'd say the black drum *should* be fine, but you could try swapping with another color just to be safe.
                • sharphead
                  • Aug 2009
                  • 285
                  Thanks for your responses. I've a sensor ordered. Unfortunately I've none, I can borrow tried swapping the drum but no joy. Thanks
