Sharp MX C402sc
  • surecopy
    • Mar 2018
    • 42
    Sharp MX C402sc
    I purchased the manual for this machine trying to replace fuser drive gear that is is on the swing plate doses it come out from the back side or does the whole fuser/delivery section come out to replace it work mainly on Toshiba and Kyocera some Sharp took this on because times are tuff replaced fuser about 11months ago the gear is brittle and broken teeth any help would be appreciated thanks in advance
  • havokprod
    • Oct 2012
    • 161
    Re: Sharp MX C402sc
    The gear comes out from the gear side /metal swing plate side of the machine. A few C-clips/E-clips and the spring and some plastic bushings. Not the assembly side/ rear of the machine. I would remove the main door to give you space to work it makes it easier. Pro tip one of gears has a pin that is super easy to lose. Stick a magnet on it. My 2 cents is that this box is an absolute dumpster fire because of the fuser unit, but I get it times are tuff. Good luck
    • JLSam
      • Jun 2015
      • 605
      Re: Sharp MX C402sc
      I agree with Havok, especially with that pin. You will get a better view if you remove the upper delivery unit above the fuser, it's only two screws.
      • surecopy
        • Mar 2018
        • 42
        Re: Sharp MX C402sc
        Thanks guys for your help everything went well also appreciated your tips
