U2-74
  • boutn
    • Jun 2016
    • 547
    #16
    Re: U2-74
    Originally posted by mloudy
    Log in as Administrator.
    Systems Settings
    Security Settings
    Conditions Settings
    √ If Firmware Corruption is Detected, Restore It
    i cant find this option...there are a lot of Condition Settings in security settings, but none of them has the firmware section...
    • mloudy
      • Oct 2015
      • 781
      #17
      Re: U2-74
      It may only be visible through the web interface an not at the control panel.
      • mloudy
        • Oct 2015
        • 781
        #18
        Re: U2-74
        • boutn
          • Jun 2016
          • 547
          #19
          Re: U2-74
          [ATTACH=CONFIG]61117[/ATTACH]
          Found it! Doesnt appear on the MX6070, but does on the MX2651.
          Thank you!
          • Demon33
            • Jan 2019
            • 38
            #20
            Re: U2-74
            Had the same case MX-3571 U2-74
            Good luck
            • boutn
              • Jun 2016
              • 547
              #21
              Re: U2-74
              Even with the check firmware setting set to OFF, error still comes back.
              We dont know anything or anyone who repairs motherboards, nor has Sharp ever told us of such a thing, so replacing the board seems like the only option.
              • Hansen88
                • 1065
                #22
                Re: U2-74
                Hytec does sharp board repair
                • boutn
                  • Jun 2016
                  • 547
                  #23
                  Re: U2-74
                  Maybe something in europe?
                  • boutn
                    • Jun 2016
                    • 547
                    #24
                    Re: U2-74
                    This just popped into my mind again, and the strange thing is, this only happens if you update the FW to a specific version, i dont know what version, but a lot of machines give this error the day after you did a FW update.
                    • Sven94
                      • Sep 2023
                      • 28
                      #25
                      Re: U2-74
                      We have the information in Germany that the mSATA may be damaged. You need to change that and do a FW Update, then it should work normally.
                      The IP Adress will get lost, when you change the mSATA.
                      "The error code U2-74 is usually displayed when the firmware files are corrupted. According to the service manual, this error can be resolved by updating the firmware with Sim 49-1. However, in this case, the update was not successful. The cause of the issue was a defective eMMC /mSATA module."
                      • timroz
                        • Oct 2020
                        • 18
                        #26
                        Re: U2-74
                        I recently went down the rabbit hole with this code on a MX-8081. We replaced the mSata without success. My DSS recommended running sim 60-1 Memory Check. I found that ICUM tested NG, which is a soldered on DIMM to the MFP pwb. Replacing the MFP pwb resolved the issue.
                        • austonrush
                          Sharp & HP Tech
                          • 234
                          #27
                          Re: U2-74
                          Agreed, this is an excellent way to verify if it is the board or Msata that is causing the error. Hopefully you can fix it with the first component every time once the issue has been verified through sim 60-1
                          • articcat182
                            • Nov 2014
                            • 24
                            #28
                            Re: U2-74
                            Guys,
                            We had two MX-3571's having the code. One the screen would go blank on, the other one just kept popping the code. We ended up having to replace both MFP/SCN PWB's in those units.
                            I found this out, the reason why the error goes away is because the DDR4 is corrupted for a certain lot of these machines.
                            So, Hytec repairs are the cheapest way to go with it.
                            Or, if you have a lease return going back, swap it out, the machine will be fine when the leasing company checks it out.
                            • boutn
                              • Jun 2016
                              • 547
                              #29
                              Can we do a DOWNgrade of the firmware using emergency firmware update to version 5 or so, so the error goes away?
                              • articcat182
                                • Nov 2014
                                • 24
                                #30
                                I had a MX-3071 that was in the serial number pool, I upgraded the firmware from 5 to 6.14 popped the U2-74 code immediately. Downgraded the firmware back to 5 code went away. At least in this case, has not returned yet.
