Cold Mx 850rt
  • ntbann
    replied
    Re: Cold Mx 850rt
    We used to throw konica neoprem rollers in the freezer. pop right off the hub and put on kyo hub.
  • Nachoman4life
    replied
    Re: Cold Mx 850rt
    Just my first time taking a vid of them cold, have had it happen before also.
    As for thermal contraction, I believe the hub is affected more than the neoprene rubber is making the roller come off of the hub.
    Just a little fun thing, to show customers how cold can affect small things like this.
  • JLSam
    replied
    Re: Cold Mx 850rt
    Shouldn't it... constrict in the cold? I always learned that the cold decreases the movement of atoms, causing them to use up less space, and therefore said material would constrict. Heat creates more kinetic energy in the atoms, hence more movement, more space needed in between atoms, therefore materials expand.
    Maybe I need to go back to school.
  • DavePo
    replied
    Re: Cold Mx 850rt
    We have had that for 5-10 years now. Sharp says no problems. I usually threw them in a microwave for about ten seconds warmed them up enough to stay put.
  • Nachoman4life
    started a topic Cold Mx 850rt
    Cold Mx 850rt
    Literally put them in my armpits to warm them up enough to work, the prefeed roller was new also, the right most one was room temp. Not the first time the cold has done this.
