mx2651 error l4-03
  • oscarconil
    • Oct 2021
    • 27
    mx2651 error l4-03
    Hi, I have two machines with the same problem, both with error L4-03.
    The fuser, the entire wiring, the fuser motor, and the control board have been replaced.
    The firmware has also been updated.
    I don't know what to do anymore.
    Thanks.
  • yurisan
    • Dec 2007
    • 113
    Thanks.
    Does the fuser turn & sound normal in Sim 6-1? By control board, do you mean you changed out the PCU (if the fuser motor runs, it's NOT at all likely to be a bad PCU)? Is the L4-03 immediately pop up, or is it intermittant? Did you try a brand new fuser, or just one out of another machine?
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 665
      Did you ONLY replace the motor? These machines have a bulletin/update for a drive gear and shaft that it attaches to, since teeth break on the original gear.
      • Hart
        • Feb 2024
        • 366
        • oscarconil
          • Oct 2021
          • 27
          Originally posted by Hart
          Hello, these parts aren't from the fuser motor block.
          The error says it's from a fuser motor block.
          Does this have something to do with it?
          Thanks.
          • Hart
            • Feb 2024
            • 366
            Thanks.
            • oscarconil
              • Oct 2021
              • 27
              Okay, I'll order it today.
              Thanks.
              • oscarconil
                • Oct 2021
                • 27
                I've changed the parts and the same problem persists.
                • ihatefinishers13
                  • Feb 2020
                  • 665
                  Did you reference this at all? https://service.sharpamericas.com/id...N/CCE-2282.PDF
                  • bilyahn
                    • Dec 2006
                    • 1470
                    This is from another tech that I work with, haven't seen it myself on this model
                    "Check the pressure sensor and spring behind the front cover below the op panel"
                    Apologize if this has already been mentioned.
                    Good luck.
                    Bil
