MXC303WH P_ON jams
  • Charli3
    • Jun 2025
    • 3
    MXC303WH P_ON jams
    Our customer had not reported the fault, but I was passing one day and happened upon the problem.
    It seems they will send a print job and the device power cycles. They will get three - seven 'jams' in a row. Then it works fine.
    Also it seems to happen at a particular time of day as though it is a specific job type. Unfortunately I cannot seem to get this theory narrowed down.
    Any ideas? we don't have many of these in the field.
  • ridgemill
    • Sep 2017
    • 190
    Have not had this issue before; however, the older Neo models had an issue with power cycling due to SNMP glitches. It may be the same here.
    You can disable SNMPD and SNMP-TRAP, both in Security Settings. Or, disable bi-directional communication in the printer driver.
    • Charli3
      • Jun 2025
      • 3
      Thanks friend. I will give that a try
      • odinp
        • Jun 2019
        • 33
        P_ON jams usually mean the machine has been turned off and on without clearing a jam.
        • Hart
          • Feb 2024
          • 415
          Found this for other models :
          M350N : A print job is crashing the spool
          MX2640N : Check the RAM (dirt, locked in position) or replate it
          MXB355W : Check the mass from the cassette tray 1 (a small metalic thingy near the gear)
          CR5 : DC PWB fault from factory
