error code L4-50 on MX2314
  • caini
    • Oct 2015
    • 27
    Hi, everyone. I was trying to fix this error yesterday but could not locate the fan, from the part manual, it seems it is behind the fuser but just could not find it, can anybody help? Thanks.
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: error code L4-50 on MX2314
    are you in the US? i don't see that model on the website. Maybe there is an equivalent model I can try to help/
    • caini
      • Oct 2015
      • 27
      Thanks. I am in Australia.
      • mloudy
        • Oct 2015
        • 775
        There are two process unit fans and a sim test should tell you which one is bad.
        • caini
          • Oct 2015
          • 27
          [ATTACH=CONFIG]52083[/ATTACH]
          Thanks. That's right. The error code indicates the one on the upper left one, I removed the fuser and could not find it at all, do you have any idea where could it be and is it hard to reach it? Thanks
          • bilyahn
            • Dec 2006
            • 1470
            Looks like you will need to remove the back panel. a lot of screws but then you should see it.
            Good luck
            Bil
            • ntbann
              • Jan 2012
              • 626
              Is it the ones located above the transfer belt?
              • Craigcul
                • Aug 2017
                • 70
                The one is in front left hand side next to where the hard drive would be the other one is at the back near the ozone filter.
                Sent from my iPad using Tapatalk
