Mx7081 Jamming
  • PillarWizard
    • Dec 2023
    • 33
    Mx7081 Jamming
    Experiencing a constant jam with the sensor p_fpfd (looks like the sensor right above the fuser)
    Seems like the paper refuses to be taken in just before the fuser and folds up accordian style when removing.
    I've cheated the door and tested both the transfer and fuser, seems like both are operating fine. Force fed paper in and it did pick it up, but behind closed doors that's not the case.
    Unfortunately we do not have a spare unit to test parts out on, so im wondering if there's any trouble shooting ideas you might suggest.
    Cheers.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 726
    The sensor is directly BELOW the fusing belt/roller on the bottom of the fusing frame. Just clean it off.
    • ricohrice
      • Dec 2008
      • 42
      I would check the drive coupling on the primary transfer belt unit, I've seen several break and you will get random copy quality issues and if I'm not mistaken that exact jam code.
      • PillarWizard
        • Dec 2023
        • 33
        [Resolved]
        It indeed was the belt drive shaft. The pin holding the gear snapped causing the transfer belt to halt with enough resistance.
        Took a while since spinning it manually with my hand showed no problems, but as soon as I simulate tension on the gear, it would lose traction and spin freely without the belt.
        Replaced the part and all is well.
        Cheers.
