DSPF hinge stops
  • bigdaddyooo
    • Dec 2014
    • 218
    DSPF hinge stops
    I looked through every model DSPF to look for the metal plates on the back of each hinge to stop the feeder raising to 12 o'clock. Looks like you get them ONLY with buying the hinge!! Does anyone happen to have a part number for them? TYIA
    OBTW the ones from the MXM365 DSPF's are different
    Are you the police? "No ma'am, were musicians"
  • mloudy
    • Oct 2015
    • 791
    Re: DSPF hinge stops
    What model are you looking to get hinge stops for? I have a warehouse full of older equipment that probably has the stops you need. I might have some already stagging to head to the scrap metal yard.
    • bigdaddyooo
      • Dec 2014
      • 218
      Im starting with the MX3050 and above DSPF
      • mloudy
        • Oct 2015
        • 791
        Are these what you are looking for? The top one is from a newer model DSPF (MX-4070V) and the bottom one is from and older DSPF.
        I installed the older on a MX-4070V and it stopped the adf bit a bit too early. I think the ears could be ground off a little to make it work.
        • bigdaddyooo
          • Dec 2014
          • 218
          The one on the top...YES both look like that on the top but the left hinge back is wider than the right. (looking from front of machine)
          The one on the bottom....NO those look to be from an MXM356 DSPF
          If you have any I will pay you for them and shipping. TYVM
          • mloudy
            • Oct 2015
            • 791
            With these being newer models I have only one machine in the warehouse I can take them off of and send you.
            That being said, you can use M365N brackets and trim them down to get the same outcome.
            • bigdaddyooo
              • Dec 2014
              • 218
              HUGE shout-out to Mark. TYVM sir.
              [ATTACH=CONFIG]52332[/ATTACH]
              [ATTACH=CONFIG]52333[/ATTACH][ATTACH=CONFIG]52334[/ATTACH]
              • lky1978
                • Mar 2009
                • 483
                lol
                Sent from my M2102J20SG using Tapatalk
